436-XDE Serial Number
C11 XFF
I now have my new 436 mounted on the wall.....I will post some pics later, but in my haste forgot to note the serial number on the back of the screen. I don't want to have to take it back down so I was wondering if the serial no. is shown anywhere in the hidden menu.
If someone knows their serial and can check to see if it is there I would be very grateful. There is a long number at the top of one of the pages, but I am not sure if this is it.
Bl4ckGryph0n
I can't check it now...But I recall that when using a utility called monitorinfo on my laptop via an HDMI connection it returns the serial number as part of the general information...Might be worth a try....
Galaxian
The serial number is also on the top of the frame, at least it is on mine. I assume this is to get round the problem you're finding yourslef in at the moment ;)
Trending threads
