435xde VGA native?
Discussion in 'Plasma TVs Forum' started by PioRow, Apr 4, 2005.
  1. PioRow
    PioRow
    Jan 28, 2005
    848
    +19
    Will the vga port on the front of the media box for the 435xde accept native resolution of 1024X768??
  2. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    Yes
  3. PioRow
    PioRow
    Jan 28, 2005
    848
    +19
    so if you can get your pc to output a 1024X768 picture via a vga cable you will have a prefect pixel to pixel match? Then couldnt I run downloaded movies and watch them?
  4. cboy
    cboy
    Dec 29, 2004
    559
    +4
    yes
  5. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    yes
  6. PioRow
    PioRow
    Jan 28, 2005
    848
    +19
    only problem is that the xde is a widescreen and my PC monitor is 4:3 ratio display so all the movies will look wrong. damm. Be interesting to see the wmvhd demos though.
  7. PioRow
    PioRow
    Jan 28, 2005
    848
    +19
    seems my graphics card has a DHTV mode that sets the PC into widescreen 1280 X 720 at 60mhz. SO does the vga port accept this input or am I gonna have to mess around with the HDMI port?
  8. bigddd
    bigddd
    I have a further question on this issue. if my pc/laptop has a DVI output and I convert it with a cable to HDMI and plug it into my 435 XDE will it be of similar picture quality to a dvd player with HDMI output?
  9. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    :rotfl: :rotfl: Thought you didn't like homework! The quality is pretty equivalent, yes, but it's a bitch to get working. 1280/720@60Hz is where to start. You can't get native via HDMI, it's not DVI :rotfl:
  10. Ath3na
    Ath3na
    It was a pain to set up. But I now have my XDE running on dvi from a Radion X800xt. 1080i is just out of this world and was worth the last 3 days on the forums.
  11. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No overscan or funny business? Would you post your settings, and driver version, for the benefit of mankind?
