435XDE Screen Extended Mains Cable
ap69
Hello all
I need to source an extended (c.3m) mains cable for the above, which I wish to run through conduits.
Any idea where I can purchase one, or perhaps buy the components to make one (have never tried that before)?
Was thinking about using a plug extension lead, but that adds too much thickness to the cable for the conduit.
Thanks in advance.
L
loadsofleads
Hi ap69, you can buy mains cable, iec connectors and UK plugs separately and build a custom made cable to your requirements. Supra make the excellent LoRad mains cables that come in both 1.5 and 2.5 versions, both are shielded but the first is 8mm in diameter and the second is 11mm. They also make excellent iec's and UK plugs :thumbsup:
Supra LoRad
Ingo Bingo
we are putting a powerbuy on manis see my other thread, just looking for someone to buy 10m
We have 3 or 4 so far
Ingo
