435xde reverting to C4??
Discussion in 'Plasma TVs' started by ikon66, Jun 17, 2005.
  1. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    Still lovin my xde but a little quirk has arisen :thumbsdow no matter what channel it is on, when I switch it back on it starts on channel 4.
    I know it's no big deal, but just wondering if antone else has come across this, or could it be the start of a more major problem? :eek:
    ps I switch the system off not just on standby
  2. Drd
    Drd
    Jan 22, 2005
    1,817
    Approaching the doghouse at great speed
    +246
    This is terrible ikon66,not only the fact you have a problem,but also it's one of the very few non-pv500 threads and no-one's answering!I haven't experienced this,but I do remember back at the beginning of the year someone had a similar problem which IIRC turned out to be a software problem on the media box.I've tried a search but can't find it.Hopefully they're out there somewhere.........
    Good luck
    Ian
  3. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    I was concerned that the mods would take it off forum for innapropriate content ;) I also read about someone whose box was resetting itself back to factory settings when they switched off, not overly concerned at the moment, will wait and see
