435xde resolution question
Discussion in 'Plasma TVs Forum' started by ikon66, Jun 30, 2005.
  1. ikon66
    ikon66
    Mar 22, 2005
    450
    Tyne & Wear
    +5
    Ok, don't wanna sound thick but when I'm viewing my plasma and change channels the dialoge box in the top RH corner dispalys the channel and time etc it also displays 625i
    What is this? is it the resolution? and what does the i stand for.
    Also is it possible to increase the resolution or is it set by the source.
    cheers
    Paul
  2. ikon66
    ikon66
    Mar 22, 2005
    450
    Tyne & Wear
    +5
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    thats standard pal interlaced, 625 lines (576 visible) interlaced. If you feed it ntsc progressive, it would display 525p. feed it 720p hdtv and it will display that. the resolution is set by the source, unless you get a scaler to upscale to hd res. or get a dvd player with scaling built in.
  4. ikon66
    ikon66
    Mar 22, 2005
    450
    Tyne & Wear
    +5
    cheers for the info :lesson:
