435xde media receiver and sound
Discussion in 'Plasma TVs' started by BIGMAX, Mar 31, 2005.
  1. BIGMAX
    BIGMAX
    Jan 11, 2005
    740
    +18
    Hi all,
    Been trying to connect the xde media receiver to my cinema system by normal red and white phono leads to obtain sound for sky viewing (sky connected to MR with scart)
    so I can keep the optical connection from the cinema system for the dvd player.
    I can't get sound through the standard inputs with phono's. Is sound only possible by running an optical cable from media receiver to cinema system as my old tv took these leads and outputted the sound.
    Any help greatly appreciated.
  2. deanym
    deanym
    May 29, 2004
    1,789
    +141
    Bigmax,
    My box is fine to home cinema receiver.
    Maybe your receiver is set to receive a digital signal on the input you're using rather than an analogue one?
    I made this mistake a while ago linking my video to the receiver.
    Or is the sound switched off completely in the tv settings?
  3. BIGMAX
    BIGMAX
    Jan 11, 2005
    740
    +18
    Thanks for the reply dean,
    I havn't tried to change the sound settings on the cinema system but I will have a look later. Regarding the tv - I can only access the sound settings for volume, tru surround etc, nothing to change any outputs.
