435XDE HDMI usage
Discussion in 'Plasma TVs Forum' started by Setch, Mar 2, 2005.
  1. Setch
    Setch
    Jan 31, 2005
    81
    9
    I currently connect my NTL digital Pace box to the 435XDE media box using a high quality scart/scart lead and I am pleased with the PQ. But I keep seeing that the 435XDE likes a digital connection, so if I was to connect it to an A/V receiver component in with HDMI out, would I notice any major improvement in PQ?
    Panasonic do a recieved SAXR70 that has HDMI out and it is not expensive @ £290.
    Setch
  2. MPK
    MPK
    Nov 26, 2004
    478
    London
    +8
    Probably not as the signal would still be converted from digital to analog and back. Most receivers also wouldn't allow component in and digital out of the same source (my A1XV doesn't), only some scalers do. But if you wait a few months, Telewest (and no doubt shortly thereafter NTL) will introduce a new HD capable set-top box/PVR by Q4 05 which will have an HDMI out, which would deliver a pure digital signal.
  3. Setch
    Setch
    Jan 31, 2005
    81
    9
    That's what I have heard, but getting anybody from NTL to give you a clue is impossible. I guess you are right in that I should wait, it would probably be foolish to spend on something that is not really needed or even redundant in a few months.
    tks
    Setch
