435xde firmware - where to get it?
Discussion in 'Plasma TVs Forum' started by deanym, Apr 22, 2005.
  1. deanym
    deanym
    May 29, 2004
    1,832
    +142
    As per the title, does anyone know where the latest firmware for the pioneer 435xde can be had?
    Also how is it installed onto the set?
    Thank you.
  2. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    I imagine through the RS232 (??) input and from a laptop/pc. Guessing. That's if it is possible at all.
  3. fella
    fella
    Deanym
    I think Pioneer only update your screen when you have problems with it,like I had,such as channel skipping and loosing sound presets.Just contact your dealer and he will tell you.
    You have the same problems too?
    The update is done via a laptop,takes about 5-10 minutes or so,and you see the green and red led's on the left side of the screen flashing.
    After that you have to setup the screen again.
    No problems for me anymore.
    Best regards
  4. deanym
    deanym
    May 29, 2004
    1,832
    +142
    Hi Fella,
    No problems as such - just like to have the latest of everything!!!! :D
    hate to feel as if I'm missing out on something!!!
    I'll call my dealer see if he has it.
    Cheers for the info.
  5. fella
    fella
    If your screen is from january or later,chances are that you already have the latest firmware.Mine is from september so I had the old version with the bugs.
    I'll hope you get the latest version,sofar I know bugfree :)
  6. Rcww
    Rcww
    Nov 19, 2004
    884
    +23
    What the current firmware version?
    cheers
