435XDE big problem - HELP
Discussion in 'Plasma TVs Forum' started by dvdchild, Jun 26, 2005.
  1. dvdchild
    dvdchild
    Aug 10, 2004
    5,690
    2
    +441
    I purchase an 435XDE today and was working ok with hdmi and digital tv.
    Turned it off and then switched it back on later. Media box switches on & screen clicks on with a black screen and then 4 seconds later both media box and screen go back into standby. I did set the no signal & power save options on before powering off but it won't even let me turn on menus or switch av inputs.
    Is my TV proper bo%^xed or can it be reset at all. i have left power cables out of both for 30 mins and still nothing.
    Help would be appreciated as not a happy bunny at the mo :mad: :mad:
    DVDCHILD
  2. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    have you tried returning it back to factory settings, or will it not even allow you to do this... directions should be in your manual
  3. dvdchild
    dvdchild
    Aug 10, 2004
    5,690
    2
    +441
    won't even let me do that - without media box plugged in all you get is 2 big squares on screen flashing red then green
  4. ikon66
    ikon66
    Mar 22, 2005
    450
    Tyne & Wear
    +5
    try the pioneer support, I had a couple of little niggles, not as major as you though, and they reply very quickly, usually the same day, and they were spot on with their diagnosis
  5. dvdchild
    dvdchild
    Aug 10, 2004
    5,690
    2
    +441
    looks like the media box has blown as it keeps powering up - black screen and then powers off.
    dvdchild
  6. ikon66
    ikon66
    Mar 22, 2005
    450
    Tyne & Wear
    +5
    spose you've done the basics and checked all your connections for shorts etc
  7. dvdchild
    dvdchild
    Aug 10, 2004
    5,690
    2
    +441
    connected up media box with just the system cable and nothing happens.
    if you disconnect one part of the system cable it gives the media box not connected error so it's either the system cable socket on plasma or media box or cable or all 3
    All i can say is that i ain't happy after only having the screen for a little over 1 hour.
  8. dvdchild
    dvdchild
    Aug 10, 2004
    5,690
    2
    +441
    well spoke to pioneer to day and they reckon that media box had shorted screen out and also media box connection. I took it back and got a full refund as i was not impressed with screen. 30 minutes has got to be the record for failure on any plasma.
    Bought a PW7 from RS for £999 and very pleased with results.
    DVDCHILD
