435 xde
Discussion in 'Plasma TVs' started by sparkymarky, Dec 20, 2004.
  1. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,071
    48
    cornwall
    +32
    Two quick and easy questions:(i'm norm a panny fan but just considering a pio as i prefer the look as a piece of furniture with gloss surround)
    1: How is 435xde media box connected to the panel? what sort of cable
    and signal?
    Plus do you have to use the box, i mean are there any connections on panel itself?
    2:I think i read it but just checking, the pio is hdtv compatible(at moment anyway) wheras panny isnt? correct?
    Oh and is the xde the best pio 'version' to plump for? Does the integrated tuner degrade pic quality compared to fde??
