434 another problem??
Discussion in 'Plasma TVs Forum' started by jason t, Nov 26, 2003.
  1. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    hi i have a 434 hde which arrived just under a week ago and everytime i watch it i think there is too much green in the picture and no matter what i do i cant get rid of it (some blacks tend to have a green tinge and also greys )just wondered had any other 434 owners suffered the same problems or any ideas how to get rid of it :confused:
    jason
    i am slowly starting to consider returning this item :(
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    A bit off topic, but I too have been looking at the 434 since its launch, but as time goes on, I am looking more and more at the SD or HD Panny 6 - not because of these minor niggles (although they dont help) more in the way of the display suiting my needs more and generally preferring the picture...I am about to demo all models soon to be 100% sure of my decision, then looking to buy early Jan - I will report back on my day, after my visit (as did tbrar)
    As for the green stuff - check out here...
    http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=329968&highlight=green
    I guess it will be the same for the UK 434, hopefully some other members will post...
    Maybe people are just looking to hard? :suicide: (for problems that is ;))
    JJ
  3. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    Jason
    I have most definitely not seen anything like that on my 434 that I had since November the 1st. Perhaps a silly thing to mention....but if you are using scart or even component, have you checked that they are plugged in / connected properly?
    Perhaps anything changed by mistake on the picture advanced settings?
  4. joys_R_us
    joys_R_us
    I can also confirm that there is definitively no green tint on my screen. I would return it to Pioneer...
  5. hutchys
    hutchys
    Feb 4, 2002
    135
    16
    Jasonjo
    i to am looking at either of these pannys leaning slightly towards the phd look forward to your comments.seen tbrar opinions also, another opinion would not go amiss.
    jim
  6. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    ok, booked in for the 8th Dec @ av-sales - will post findings on my return...
    JJ
  7. MTJ
    MTJ
    Sep 26, 2003
    38
    Hampshire
    Jason,
    no problem like this on my 434. Report it to Pioneer.
    Mark
  8. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    yes i will,i am waiting to hear from them with regards to my media box so next time i speak to them i will mention this
    jason
