Turlough
I've just tried connecting (one after the other) two different DVD players via component (3 wires only) to my 433MXE (5002 card). Nothing on Input 2 for either.
So far I've:
- been through Interlaced & Progressive set-ups on both DVDs.
- gone into the plasma installer menu (menu then power on) but can only adjust the option part of the Input 2 menu (both with and without a disc being played).
I understood that the installer menu allows the component input to be set (1 or 2) but I can't see how to get to the other parts of this menu.
The S-video connection works fine from both DVDs.
How do I make the panel believe it has component connected ?
So far I've:
