433HDE v Fuji HHA42 using sky+
Discussion in 'Plasma TVs Forum' started by modeller, Mar 7, 2003.
  1. modeller
    modeller
    Nov 29, 2002
    57
    yateley
    Just got back from 7oaks looking at the Pioneer and Fuji using a sky+ feed.
    Pioneer RGB Scart into tuner box
    Fuji RGB->Component
    Watched a mixture of sky movies and BBC1 (In Deep) from the sky box as it is our primary source.
    Verdict, Pioneer more watchable, fewer artifacts, far less solarisation. I found the Fuji brutal on this source. Comment from 7oaks was that the Fuji was better on DVD material, though I didn't verify this.
    The smaller Fuji is behaving in a similar way to the HCA50 that I viewed earlier in the week.
  2. steve36
    steve36
    Dec 11, 2002
    958
    Warwickshire
    +33
    Now I am confused, here I am waiting months until FJ dain to allow one of these screens out to suppliers and when they finally get here they are not as good as I hoped.
    Srooks,
    I am a little surprised by your findings and until your comments had almost considered ordering without seeing a proper head to head !
    When I viewed a 4242 against the Pion HDE, I actually thought there were more artifacts from the pioneer in movement shots.
    I thought the 4242 was slightly better, but I did not buy because the 4242 seemed too soft at the edges, even when sharpness was turned up.
    Anyway thanks for the warning, maybe I should try and catch a bargain price 4242 quickly before they disappear.
    Steve
  3. modeller
    modeller
    Nov 29, 2002
    57
    yateley
    steve,
    I'm just as disappointed, believe me. Joe has just posted comments about the HHS442.
    Remember I was viewing sky, which has its own demands.
    The worst thing about the Fuji was solarisation - it just didn't appear to have enough colours. Panning movement also looked poor.
