433 mxe hours used meter
Discussion in 'Plasma TVs Forum' started by themmings, May 14, 2003.
  1. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    How can I find out how many hours are on my 433mxe?
    I want to get Grodon down to calibrate the screen but I've heard it's wise to wait for around 100 hours use on the clock before calibrating new screens...
    Tim
  2. philipb
    philipb
    Mar 6, 2002
    2,058
    63
    Swindon
    +153
    Get into the integrator menu - power off, then press menu followed by power on and you have the menu. I think hours used is under the extreme right menu options - can't remember what its called.
  3. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Thanks Philipb.
    Anybody else know what the relevant menu relating to 'hours used' is called?
    If it's obvious then fine. If it's not then I don't really want to go lurking around in there without knowing straight away where to go and which button to press.
    Tim:)
  4. DJP
    DJP
    Jan 10, 2003
    74
    Hampshire, UK
    +5
    There's actually a simpler way to display the "Hour Meter". Press Display to bring up the picture information and then while this is on screen press and hold Display for a few seconds. This will show the Hour Meter, temperature etc. without having to go through the integrator menu.
    FYI in the integrator menu the Hour Meter is under "Option" then scroll down to the second page. The "Hour Meter" is at the bottom. Note that if you want access to the other items in the integrator menu there must be a signal present for the currently selected input.
    I hope that this helps.
    Derek
  5. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Thanks Derek - nice tip.
  6. ncpl
    ncpl
    Jan 21, 2003
    353
    Surrey
    DJP,
    Nice to see you around again. A few months in now, have you got any further thoughts on PQ via the various options you originally tried ?
    I'm now only 3 weeks in to the MXE and am going to hang on whilst it runs in before messing around too much. So far though, DVD is quite spectacular.
    Best rgds
