43" TV for the bedroom? £300 to £350 budget
Ice_Black
I am looking for a decent 43" TV for the bedroom to hang on the chimney breast. I will be watching TV from my bed (opposite of TV).
I don't play games, so it needs to be decent quality for Freesat and HD quality from Plex and Netflix. SD quality should look great too.
My budget is £300 to £350.
I am considering SAMSUNG UE43TU7100KXXU but it is slightly over my budget but it is fine. Good pick? or is there a better TV with the same/samilar price range?
vickster
You won’t get HDR from a 43” so it doesn’t matter too much what you buy. Look at models with narrow viewing angles
Are you looking for a built in Freesat tuner?
Ice_Black
A Freesat tuner would be nice to have.
vickster
This LG has Freesat and in budget with 5 yr warranty
Or a few quid more, you’d need to compare specs for differences
Ice_Black
Look like 48" size come after 43" - will 48" work for me?
TV will be mounted on the chimney breast wall. It will be 3 meters distance from a chimney breast to bed (watching from straight angle)
vickster
I’d say at 3m, you’ll be fine, could even go bigger for HDR material...but a £300 49” will have the same inherent issues with quality as a £300 43”
Ice_Black
I can't go any bigger. The width of a chimney breast is 56"
Which TV would you go for 49” or 50"?
I had a look at the @Dodgexander Guide and it mentioned that Sony 49XH8505 for Mid tier and Samsung 50TU7020 for Low tier
Im increasing my budget to around £500
I won't be playing games, mainly watch on FreeSat, Youtube, Plex, Netflix. I don't watch sport. I like TV depth narrow, not bulky as I will be mounting on the wall.
Ice_Black
I've decided to go with Low tier.
I might go with Samsung 50TU7020 or LG 50UN7400
Which one is better?
It is not clear if Samsung 50TU7020 has a Freesat tuner, I can't find any information.
Ice_Black
@Dodgexander I want to ask, is this mistake from your best value guide?
You have LG 49UN7300 for wider viewing angles but LG 50UN7300 for narrow viewing angles.
Both are the same model but different sizes.
vickster
No it doesn’t at least according to the John Lewis full spec
vickster
They have different panel type. 49 is IPS (wider angles, poorer blacks), 50 is VA (narrow angles, better in dark viewing environment)
Dodgexander
@Ice_Black look at the link I posted with the Samsung models to compare tuners:
Variations:
TU7002 : DVB-T/T2/C
TU7102 : DVB-T/T2/C / Google / Alexa
TU7122 : DVB-T/T2/C / Google / Alexa
TU7172 : DVB-T/T2/C/S/S2 / Google / Alexa
The TU7020 is a regional variant of the TU7002 and lacks a Sat tuner (indicated by S2). The TU71xx models should have one, as well as the even higher numbers.
There's no mistake, at 50" all TVs use VA panels, even LGs. Their TVs at 49" use IPS though.
Regarding which is better between an LG and Samsung 50" its really hard to tell. I'd say the smart TV of the LG TVs are better, but some people prefer Samsung. Picture quality will be very similar, but the Samsung will have the edge with its accuracy out of the box, which you may prefer if you don't want to pay for pro calibration.
Ice_Black
Thanks for the help guys.
I've ordered Sony 49XH8505 with 5 years warrenty.
Which mount do you recommend? There is a socket on the wall and cable/adapter should be hidden behind tv.
Dodgexander
Any will be fine, just match up the VESA hole spacing of the TV with the mount you buy. Make sure the mount supports the weight of the TV.
Ice_Black
TV arrived today and then switched on the TV... This is what I see 😞
What the hell?? I am going to have to ring Martin Dawes tomorrow
Samsung Micro LED, Mini LED, NEO QLED TVs and More: AVForums Podcast Interview
