DeadStaar
Hey guys, so I’m using the X85J, 43” TV, on my PC and it looks sickly. I don’t have the text/ font issue everyone else seemed to have. That looks fine. I am running the display at 4K@ 120Hz.
In short:
YCbCr 4:4:4 and TV set to Auto is washed out to the point of looking like a 16bit Windows 95 desktop. Setting HDMI rangr to Limited is only subtly better.
RGB 4:4:4 (Full) is much better, but the saturation (?) issue continues, but setting the HDMI range to Limited pretty much perfects it.
Turning HDR off, only on the TV results in an extremely washed image (not pictured), it looks a bit like the first images, but worse. Setting HDR to Off on both PC and display produce an image pretty similar to RGB 4:4:4 (full) and HDMI range set to auto. Which is a very subtle washed effect. So it appears even turning HDR off is not the solution.
Moving over to Halo: Infinite, using the best settings I found for the previous game, Elite: Dangerous, it seems to hold but I wonder now if this is considered crushing blacks(?). But setting to Auto isn’t bad either. Any ideas of what I may be missing?
Now, I just noticed, while turning HDR off on PC and the TV made Halo look more washed out than ever…except when I Alt+Tab to switch the app, you can see the thumbnail of the game running looked perfect. Now Halo doesn’t have a committed Full Screen option, only a borderless windowed mode, a thing many have been complaining about, mostly because of the better performance gained by running in dedicated full screen mode. Elite, on the other hand runs Full Screen.
In short:
