N
nicccole
My first thread so bear with me
Interested in the Toshiba 42WP16 @ 2999.95 from Richer Sounds.
Going to go into my new flat in a months time.
I getting some walls moved around at the moment and was thinking of getting it recessed (have I spelt that right) fairly flush into the wall. It's all stud walls with timber joists.
1)Anyone done this?? Good idea? I know it will be a pain to remove, but hoping I won't have to do it every 5 minutes)
2)Wall mounts - are they 'up and off' or unscrew (which would be a major problem if it is recessed.
3) Also 250.00 for a wall mount - are they mad?? Can I not get one made up ?? I have lots of engineering companies as clients - this isn't rocket science is it ??
4) what leads should I get installed and ducted - I only want to do this once.
5) Height of Plasma - any recognised standard heights for installing 42 inch plasmas, height from floor?? I am putting on a north facng wall so no direct sunlight - the living room is almost all windows round two sides. so didn't want direct sunlight in the summer during the day.
I have DVD / Sky, plus a TIVO.
Thanks everyone
Nic
Thanks everyone
Nic
