42WH18B tweaking problem
Discussion in 'General TV Discussions Forum' started by shaunthedude, May 14, 2002.
  1. shaunthedude
    shaunthedude
    Just taken delivery of the above set last week. I have noticed that when watching a program with the black bars top and botom, the bars are on a slant, the picture leans down to the left of the tv. i looked to see if there was one of those geomagnetic ajustments in the menu but can not find one. Also the bar at the top is wider than the bottom one. I am a total novice with tvs etc so if some kind soul can talk me through how to ajust these problems in the menu I will be grateful.
    Many thanks,
    shaun
  2. laurel
    laurel
    Shaun
    You say the bars lean to the left?
    You could try putting a small wooden chock under the left of the set to lift it, then you wouldn't notice. :D
    Or you could get a Panasonic? :p
    Laurel
  3. bob007
    bob007
    Failing that, take the castors off the left hand side of your chair/sofa.........:D
    Hope you solve your problem.
    bob
  4. shaunthedude
    shaunthedude
    yeah yeah yeah guys. very funny. im splitting my sides here with laughter.
  5. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    As a fellow Tosh RP owner I feel it is my duty to give you a sensible reply.
    There are no geometry settings available to the user, although I believe these can be adjusted in the service menu.
    Don't try this yourself, Get the engineer out to do it FOC.
    Regards the width of the black bars, are they always different widths or on just some progs? I have noticed this on mine and my previous TV but it only occured with DVDs, it's just teh way they were transferred.
    A sensible if not over helpful reply.
  6. shaunthedude
    shaunthedude
    At last, somone with sense. The top black bar is always wider than the bottom one. It looks like the picture needs moving up about 2 inches. I will get in touch with an engineer to sort out the slant. I am still very happy with the set and these problems I can easily live with. My previous tv was the panny tx42pt10 which i liked very much, however, the picture on the tosh is outstanding compared to the panny. Thanks Kevo.
  7. laurel
    laurel
    Lighten up guys. :D Just a bit of light hearted banter.
    You could try searching. there are plenty of people on here who have the set.
    A quick search revealed threads
    here
    and
    here
    So there are certainly some people who can access it.
    Try and PM them.
    Laurel
    PS. My previous tv was the Tosh which i liked very much, however, the picture on the Pana is outstanding compared to the Tosh.
    PPS. You can get chocks from B & Q.
  8. bob007
    bob007
    You will need some Duck Tape then, 2nd isle down from the chocks at B&Q.
    I had a sony before, sold it cos it didn't have scrolling bars, but now the picture i have on my thomson beats the pana and the tosh hands down......:p
