42pwd8 Just Arrived!!!!
Discussion in 'Plasma TVs Forum' started by dando, Oct 31, 2005.
  1. dando
    dando
    Its all hooked up via component box etc and the picture is awesome! Very happy bunny! Anyone thinking of getting one, you wont regret it. PS Thanks to everyone who gave me advice about this panel, you were right.
  2. UKseless1
    UKseless1
    Mar 9, 2005
    839
    28
    +36
    Nice one mate - enjoy!
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    :thumbsup: Great choice. Got mine all hooked up on Friday last week, and it is great :thumbsup: Already up to 35 hours so far :eek: :eek: , I really must get out more :rolleyes:
    Andy
  4. dando
    dando
    It was a direct replacement for a 37PV500 and I'm going to stick my neck on the line and say that the PWD has a better picture!
  5. UKseless1
    UKseless1
    Mar 9, 2005
    839
    28
    +36
    Bloomin eck - now there's a controversial statement ....... hope your wearing your hardhat Dando :)
  6. steve-o
    steve-o
    Jun 14, 2005
    408
    +5
    Glad you're happy with it dando, gonna order mine on thursday :> :thumbsup:
  7. dando
    dando
    I dont want to be controversial! Its my honest opinion. And one more thing it looks very sexy wall mounted! (As sexy as the pio 435/6!)
  8. Tosty
    Tosty
    Sep 2, 2005
    33
    Guernsey
    Very glad you're happy with it, cause I'm buying one tomorrow! And I've agonised over the tv/panel decision. A question though (to ease my mind), what are you using for sound?
  9. dando
    dando
    Hey people. Just out of interest what are your current picture settings?
  10. UKseless1
    UKseless1
    Mar 9, 2005
    839
    28
    +36
    Tosty - there are a number of options. The PWD8 has a built in amp so you can hook some speakers up to it, otherwise it's the AV Receiver route with some decent speakers.
    Dando my settings (not gotten into an advanced tweaking) in Cinema Mode:-
    Contrast -5
    Brightness -1
    Colour 0
    Tint 0
    Sharpness 2
  11. dando
    dando
    For sound I use an AV Amp. Denon 1906. The add on speakers for the panel are £200+ if you need them. Thanks for settings, I'll check mine out later (cos I'm at work) and see if how they compare.
  12. cl0nd0n
    cl0nd0n
    Sep 19, 2005
    48
    11
    +15
    Also recommend this panel!
    Just hooked mine up. Sky+ via a JS Tech RGB > VGA converter. Excellent picture!
    Denon 1906 all hooked up. Not set it up yet so any advice gratefully received!
    New 42PWD8
  13. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    My settings are, whilst still running in, so they are a bit low:
    Contrast -7
    Brightness -3
    Colour -7
    Tint 0
    Sharpness -3
    Looks good enough for me to keep on watching for the next couple of weeks before I start playing again, with DVE, to try and get it right, whatever right is :rolleyes: ;)
    Andy
  14. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    I've got a seperate AV Amp (Arcam AVR300) which I am also using for component switching of the inputs into the PWD8, NTL/XBOX/DVD, so it means one cable from AMP to PWD8.
  15. pmj_172
    pmj_172
    Oct 30, 2005
    Guys, guys, please help a novice at the edge of the PWD8 investment!
    I have sky digital, Sony DVD and theatre system. What is the best way of hooking up the DVD and Sky to the PWD8.
    Any help appreciated.
  16. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    probably the best is to go sky via js rgb to vga and dvd via component, but also sky via scart is very good on the 8 series leaving the vga free for component from dvd.
  17. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    What's the model numbers of the Sony DVD and "theatre system"? And what video inputs/outputs do they have? THis will help with recommendation.
    As mep has said, you could make use of the built in VGA port, or add extra scart board for sky or DVD, or just the VGA if you add a switcher of some kind in the middle.
    Andy
  18. steve-o
    steve-o
    Jun 14, 2005
    408
    +5
    Yeah the best way in my opinion would be to buy a few cables and a switcher and run everything through VGA. That way you got all the slots left for expansion should you require it in the future.
