42PWD7 Plasma and a ????
Discussion in 'Projectors, Screens & Video Processors' started by tauntingboar, Aug 28, 2005.
  1. tauntingboar
    tauntingboar
    Dec 2, 2002
    792
    Blackpool
    +12
    Just bought myself a panny 42PWD7 plasma and am currently feeding it with a Pioneer 737 dvd player (component). I've been looking for a new player, something with Pal progressive. But since I'm still pretty happy with the pq from the 737 I was wondering if a scaler might be a better option than say something like an Arcam DV79?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,442
    The Borders
    +2,596
    mikethomas79
    Adding an external Video Processor is a good move with the PWD7 - these Displays look best if you oversample your SD sources and Input them to the Display at 1280x720P.
    The Lumagen VisionDVI (UK SRP 795.00) is a good match with the PWD7 - you can connect on the Analogue or Digital inputs on your Display.
    The Analogue (RGBHV) Input is more flexible as it has better support for a wider range of 50Hz signals.
    Adding a new DVD player obviously may have sonic benefits and there can also be advantages to using a better player as a higher quality 'transport' to 'feed' the Lumagen Processor; though that's maybe for another day.
    Best regards
    Joe
  3. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    457
    +3
    im still learning here , but is there any difference to picture quality when connecting a scaler via analogue rather than digital ?
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    It depends on the quality of the screen inputs and scaler outputs. Panny's like yours have VERY good analogue inputs hence there is very little between analogue and digital on these displays. As Joe said, analogue fed from a scaler at 720P produces a very, very nice picture on these panels. Analogue is also more flexible on the Panny's due to the issues/problems with digital (DVI) and 50Hz PAL support on these models.
    Also, consider the DVDO scalers like the iScan HD/HD+ alongside the Lumagens. Funnily enough I can recommend them! (check my sig) ;)
    JJ
  5. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    457
    +3
    hi
    Thanks :) do you run your xbox through your DVDO ? if so whats it like
  6. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    Yes, using an Xdox hi-def output cable...this pic is very, very good, but my friends sometimes notice the video delay that the Iscan adds to games. This doesn't really bother me as I use it mainly for Xbox Media Centre.
    JJ
