42PWD6 VGA Question
Discussion in 'Plasma TVs Forum' started by Oblivion, May 25, 2004.
  1. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    I am thinking of getting the Panny and running sky through the JS RGB2VGA box, and my question is this.
    Can the VGA input on the Panny be set as the default input, so when it is turned on Sky is on the screen, without having to cycle through all the different AV inputs?
    Paul
  2. jmack
    jmack
    this can on the 4 series, so no reason why not on the later models,
    no doubt someone with a 6 will answer.
    on the 4 series its in the not very secret menu, its called initial imput
  3. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    It certainly can, it can also be set to turn on/turn off when it does/doesn't have a signal from the VGA input. It's all in the not so secret, secret menu options..
    Ryan :smashin:
  4. jmack
    jmack
    great minds as they say :smashin: :smashin:
  5. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Does anyone know if you can set the default input on the panny tuner on a PWD5? It defaults to the tuner which I rarely use, I want it to default to AV1/RGB,
    Neil
  6. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Cheers rscott4563 Justthe answer i needed.
    So how do you get into the not so secret menu? And what other goodies are in there?
    Paul
  7. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Accessing the Hidden Menu on Consumer & Industrial models :
    ( Not available on Consumer "PA" & "PX" Models )
    Press the [SETUP] button on the remote
    Then you must move down and highligth the "OSD Language" option
    Then hold down the [SURROUND] button for 5 seconds
    The Hiden menu will appear.
    Press [RETURN] button to exit the Hidden menu
    WARNING: DO NOT CHANGE ANY OF THE FOLLOWING:
    "REMOCON USER LEVEL" - "ID SELECT" - "REMOTE ID"
    OR YOU'LL DISABLE THE REMOTE CONTROL.
    To use "other " IDs, you need a RS-232 control with an ID header.
    There is also an optional "double secret probation" remote that has settable IDs.
    These are for multi-display setups, usually not residential.
    The remote user level settings are for public displays that will keep
    non-tekniken lookens-peepers from changing things.
    (Info provided by Techwizard)
    You should be able to select which ever input you want on the "Initial Input" option.
    p.s. have you had a chance to play some more with the DVI input and the judder test software?
    Ryan :smashin:
  8. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Ryan,
    Going to have a play tonight. That doesn't work with the tuner box though.
    Neil.
  9. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Ryan,
    Neil.
  10. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Here you go, this one might work.. :thumbsup:
