Hello,
I have just bought a 2nd hand 42pwd6 Panasonic Plasma Screen, which has 5000 hours of use on it.
Some quick questions.
How long should this screen last - hours of use?
Also are there anything feture of setting that I should not be using while using the screen? Anything that could damage it?
I noticed that there is a dynamic setting which looks LOADS better than the 'normal' setting. Is this okay to use all the time?
(newbie).
Jon
Jon
