42pw23p/Component/Xbox
Discussion in 'Xbox Forums' started by john316, Jun 10, 2004.
  1. john316
    john316
    Apr 24, 2003
    619
    28
    Aigburth, Liverpool
    +34
    After some advice on whether I should go down the Component road. Currently have to use my Xbox via front S-Video as Sky+ goes into SCART 1 via RGB and my main DVD player goes via SCART 2 on the Digibox. Will the Tosh play ball for Xbox games via the component? I know HDTV options are out of the question but what is the lowest component quality like to be like?
    Thanks in advance :thumbsup:
  2. inzaman
    inzaman
    Dec 16, 2002
    7,943
    Derby
    +1,021
    I know you have said hdtv options are out, but does this mean that the tosh will not accept a progressive signal?
  3. john316
    john316
    Apr 24, 2003
    619
    28
    Aigburth, Liverpool
    +34
    Apparently so - every single review I read says it can't do Progressive Scan so I assume its 480i only - just wondering what quality that will be compared to RGB?
