42PV500B Back view dimensions
Discussion in 'Plasma TVs Forum' started by TheGworks, Jul 25, 2005.
  1. TheGworks
    TheGworks
    Apr 14, 2005
    54
    +12
    Just been on to Panasonic customer care to see if they could email me a dimension sheet with a back view for the 42pv500 so that I can put the wall bracket up before the set arrives tomorrow. They don't have one yet!!!! I need the exact dimensions of the fixing holes in the rear of the panel so I can get the panel exactly where I want it. Has anyone got any details that would help??
    Grae
  2. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    186
    I think it may depend on which bracket you are using - official Panasonic or some other make.
    This might help it was posted on this thread here and I presume it is the official bracket.
    At the very least it should give you an ide of the size and hole locations
    [​IMG]
  3. TheGworks
    TheGworks
    Apr 14, 2005
    54
    +12
    Thanks for the quick response it was the fixing holes on the back of the panel I was after but the diagram gives me something to work from
