42pv500 wallmount - use panny6 wall mount?
Discussion in 'Home Cinema Buying & Building' started by FaxFan2002, Jun 9, 2005.
  1. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    Does anyone know if you can use a panny 6 wall mount on the new 42pv500 plasma ?
    tar.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    dpends which panny 6 mount
  3. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    ahh... I have the proper panasonic version, should I be looking for a model number or something ?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    it will have a model number and you will need some extension bars i think
  5. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    It's a TY-WK42PV1 - any ideas?
  6. DWF
    DWF
    May 22, 2005
    75
    11
    hey sorry to butt in on your post man, but i did not wanna make a new one, just a quick question to Mal or one of the lads, i had a look at the back of my 500, where on earth are the wee holes to hang the thing? i see four big hole type things with covers on?
  7. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Thats them, take the silver caps off.
  8. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    The extension bars for mine are 45mm.
  9. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    Not sure what you mean by extenstion bars?
  10. Member 6435
    Member 6435
    Dec 18, 2000
    1,518
    Tunbridge Wells
    +324
    Faxfan2002
    Due to the shape of the PV500 some flat wall mounts cannot be used with this model as they do not hold the screen far enough away from the wall. Panasonic are now suppling their own wall mounts with these screens although there has been a delay in manufacture which has resulted in orders being held up. There are, however, some universal mounts with extension options which can be used. Depending on the type of mount you have, you may even be able to use an extension kit with this.
    Regards
    Alastair :hiya:
  11. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    OK - I'll have to wait and see I guess!
