42PV500 auto contrast can be can be disabled or not?
Discussion in 'Plasma TVs Forum' started by migas, Jun 20, 2005.
  1. migas
    migas
    Does anyone know if the anoying 42PV500 auto contrast feature :eek: can be disabled or not?
    I'm thinking about buying this plasma, but I really need to know if this can be turned off. :rolleyes:
  2. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,308
    63
    +127
    The auto can be turned off under picture setting, changing contrast to normal. Contrast now no longer changes depending on picture content etc... :D
  3. Rapid 17
    Rapid 17
    Jan 14, 2005
    892
    28
    +78
    leeboy, is this a cure for the problem FlyingBig and a few other posters on this forum are experiencing ? Geoff.
  4. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    Errr... how do you do that? On my Setup menu, Contrast is just a slider...
  5. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    Nope, completely false information. I have only spotted the problem while using normal so go figure that one out.
  6. greyhorse
    greyhorse
    Apr 16, 2005
    447
    tv has a sensor at the front, depending on settings will detect light and alter picture !!!! its in the manual.
  7. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    Sorry, greyhorse, I don't understand how you set Contrast to 'Normal'. You can set Viewing Mode to Normal (I've still got it on Cinema, of course). Is that what you mean?
    And I don't see how a sensor at the front would change the brightness of the picture caused by a bright object appearing in the picture...
    And I still can't see these sodding lines, either... :)
  8. k0rn
    k0rn
    I was experiencing these occasional brief moments of brightness changes, too.
    I´m NOT using the auto-setting.
    Here´s what solves the problem (I`m 99% sure after watching 2 shows without noticing it again)
    DISABLE the Colour Management and it *should* be gone!
    I´m using "Cinema" setting with Colour Management set to off and so far it hasn´t occured again. (to be certain 100% I`ll have to watch some more movies, though) :clap:
  9. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,308
    63
    +127
    appologies for giving fasle info, Sulis is correct (wrote message while at work :rolleyes: ) i have the viewing mode set to normal... this them bypasses the auto contrast etc.. like i said i have no change in contrast day or night or on video content contrast :D
  10. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,308
    63
    +127
    i also disable the power save feature, you'll notice an improved noticable increase in contrast! :D and like KOrn colour management is off ! god we pay for all these extra features but prefer the picture when there turned off! :rotfl:
  11. Enquirer
    Enquirer
    [​IMG]
    on page 13 the page it mentions it doesn't tell you much more.
  12. k0rn
    k0rn
    I would understand if it only happend with that Automatic-setting enabled.
    But it happens with all picture modes! So it´s definately NOT the automatic contrast sensor.
    Like i said before, turning off "Colour Management" seems to help.
  13. Enquirer
    Enquirer
    I don't have this plasma and have never used one so i can't comment on what you have seen.I totally believe you have a real problem and hope there is a quick answer to this issue.Good luck. :smashin:
    What i do find poor is the manuals discription and explanation of the CATS feature. :thumbsdow as i say on the page it says to look at (page 13) it doesn't tell you anything about CATS!
  14. migas
    migas
    Thanks for all the help! Let's hope than that with the color management set to "off" the auto constrast feature will also be permanently :clap: off.
    Altough it seems that the light sensor on the front of this PDP will always adjust the brightness :eek: , not the contrast... :rolleyes:
  15. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    Yeah, but that will be dictated by the amount of light in the room, not on the screen. This seems reasonably sensible - there's a huge difference watching a screen in darkness and in bright sunlight. I don't know how this version works, but I can't believe it would lead to sudden changes in screen brightness.
  16. k0rn
    k0rn
    I´ve got some new information:
    Panasonic Customer Support told me that disabling P-NR and MPG-NR could help eliminating the issue.
    In another note, after disabling Colour Management, the effect seems to be nearly gone. (at least it´s not as noticable as before)
