42PHD8 - Best frame rate for watching Sky ?
BeelzebubUK
I have Sky+ connected via component to a IScan HD+ Scaler and then using the VGA out to the RGB VGA port of the panel.
When watching football or other fast panning scenes I'm getting a lot of juddering. I'm assuming this is because the frame rate being output by the scaler is different to the frame rate that the panel would work best on.
Does anyone know what the best frame rate would be ? I would have thought it would be 50Hz but not at home at the moment to check what it actually is.
Thanks for any help.
BeelzebubUK
Yep you were right.
I had it set to 75Hz on the scaler for some reason. Must have been messing about with it a few days ago :oops:
The difference between the 2 watching a ticker on the screen was miles apart.
