42PHD8 & 50PHD8 Questions
Discussion in 'Plasma TVs Forum' started by leedsfireman, Oct 28, 2005.
  1. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,246
    38
    +3
    I might have the choice of both, viewing around 5m away. My questions are;
    1 - In theory will the 42" give a sharper image due it having more pixels on a smaller screen. Or will it not matter due to watching distance.
    2 - Are both HDMI inputs not up to much as mentioned on this forum.
    3 - Does a scaler, i don't really know what it does, make that bigger difference.
    4 - Can you fit 2 HDMI boards if reqiured.
    5 - And lastly what carn't these screens do which might limit there playing abillity in the future.
    Thanks in advance. :)
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,631
    Norwich
    +1,060
    1. Yes. Well HD and good dvd won't realy look softer, but low bitrate stuff will definitley look a little sharper on the 42".
    2. They are OK, but the analogue is just so good so why bother?
    3. Yes. But you will be more than happy without, more a case of don't look unless you are prepared to get your credit cards out.
    4. Yes, but look at answer 2.
    5. Not a lot really.
  3. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,246
    38
    +3
    What conections are used on the component boards, BNC or RCA.
  4. Rebel154
    Rebel154
    Sep 27, 2004
    527
    Doncaster
    +19
    Depends on which board you buy - both types of connection are available with the BNC option being much cheaper as (so I understand) it comes from the commercial department rather than the consumer department.
    When I bought my PHD8 from AV-Sales, I was told that there is no difference in performance.
    You can see the available boards here http://www.av-sales.com/products.php?cat=214&nav=16
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,631
    Norwich
    +1,060
    I would always choose the 5 bnc RGBhv board as you can then choose RGBhv or YUV with really good connections rather than RCA connectors, any deccent scaler will have RGBhv on BNC outputs.
