42PF9830 resolution
Discussion in 'LCD & LED LCD TVs Forum' started by Wall, Jun 8, 2005.
Tags:
  1. Wall
    Wall
    There was a post earlier with a link to the website of Philips in Denmark that had technical specifications on the new screens. About the 42" model of 9830, it says that the native resolution is 1920 x 1080 but the highest computer resolution is 1366 x 768...
    Does this mean we'll get the same problem as with the 9986(black boarders on the sides) that has 1366 x 768 as native resolution but can only run in 1280 x 768 when connected to a computer?
    here's the link again:
    42 inch spec
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    You'll need to run your computer at full screen resolution. ie 1920x1080. Or use VGA and scale it.
    Jimmy
  3. stereo
    stereo
    Jun 8, 2005
    3
    Jimmy,
    Could you open this 42pf9830 resolution question a little bit more, please... Are you able to use your computer with 1920x1080 resolution (graphics card set to 1920x1080, Philly showing the whole 1920x1080 resolution) or are you only restricted to 1366x768 instead? And is this through VGA or DVI?
    Thanks,
    Sammie
  4. Wall
    Wall
    Yeah, The thing is that the danish site says that the highest computer resolution is 1366 x 768 and not 1920x1080 which would map 1:1...
    The specifications might not be accurate though...
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    On past experience, It'll be best to wait and see.....
    Jimmy
