42PE50 and RGB input
docnaz
Advice please. Had 42PE50 set up and was getting RGB input on AV3. Had to unplug system to accomodaet all kit and now only getting AV3 but logo does not say RGB. Have I lost the RGB connection somehow? Sky is confiured to RGB out. Has anyone else experienced and remedied? Thanks
K
knobbs
hi av1 and av3 are both rgb, try the sky box settings from rgb to pal see if theres a difference, cannot see you losing rgb on av3.
knobbs.
cliveuk
It needs to be a fully wired scart lead, make sure you havent used a diffrent lead by mistake this time around
