Hiya, Does anybody have the Hitachi 42PD7200 Plasma screen linked up to there xbox?. If you do, could you please tell me what settings you have it on as I was playing Fifa last night and as the screen followed the ball the grass went all blurry. Thanks
I got a 7200 yesterday but couldn't get it set up untill late. Will be having a look at the xbox later, so will leave some feedback for you. What connection are you using to get the Xbox to the plasma? RGB, composite, svideo?
If you're using a plasma with your xbox, you have to get a high def kit, softmod your xbox to switch it to ntsc, and then enable progressive scan over component in the MS dash. Playing in progressive scan is lightyears ahead of using interlaced connections like RGB Scart and s-video.
Im waiting for the softmaod kit to be sent to me. I think i have the high def kit, i have a small black box half way down the cable, which i plug in a fibre cable that goes into my amp. On the end of the cable is a scart connection, and i think it connects as RGB, does that sound right?
i do The picture quality is unbaleavable when using the hi def kit,,,,,,i cant wait for the 360 to arrive ,it will be David.....................
That's not the HiDef kit but is as good as it gets in PAL land. I think that is called the Advanced AV kit & has RGB out on the SCART. You need this for progressive scan component out http://www.divineo.co.uk/cgi-bin/div-uk/xb-of-hidef
Anyone with this plasma and XBOX could your send me your plasma settings, set up for your xbox please. When i am playing fiffa the picture gets quite blurry when the camera moves up and down the field. Thanks
