42PD3000 - what settings have you chosen?
Discussion in 'Plasma TVs Forum' started by F1ash, Jul 16, 2003.
  1. F1ash
    F1ash
    Jun 12, 2003
    109
    Sussex
    I'm still tweeking the settings on my new screen but was just interested to know what settings anyone else has gone for?
    I've routed my Toshiba SD330E via component cables through my Denon 2802 amp which helps with lip sync but does slightly (very slightly) degrade the picture as opposed to running it straight from the DVD.
    After checking the picture quality difference between scart and component I've found that the components are probably too good as now the DVD pixels are so sharp you can see them even at a distance. Doing a freeze frame during Bilbo Baggins fireworks at his party in LOTR really illustrates this - the scart picture smoothes the edges more.
    Also, I was really dissapointed to find that when viewing in 4:3 the side bars are light grey - I saw this on an LG a while back and thought 'mmn, that looks a bit crap'. I can't believe they're not black on the Hitachi! Black bars are far less intrusive.
    I'm sure there isn't, but does anyone know if the colour can be changed?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Flash,
    The grey bars may be more "intrusive" but they are doing your screen a favour if you watch a fair amount of non-stretched 4:3 material. I've no idea if they can be changed though - check out your manual.
    Steve
  3. F1ash
    F1ash
    Jun 12, 2003
    109
    Sussex
    Hi Steve,
    Yeah, I know they probably are. Would be nice to be able to choose though.
  4. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    Pretty sure they can be changed to black on the 42PMA400E. Do not know about the 42PD3000, though.
  5. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    Does this panel suffer lip-synch issues across the board?
    Is it noticable in an "out of the box" manner/set-up?
  6. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
  7. F1ash
    F1ash
    Jun 12, 2003
    109
    Sussex
    The lip sync isn't really an issue - I'm just a perfectionist. I used to have really bad lip sync with my old Sony CRT when using a PS2 to play DVDs with a Yamaha amp.
    Cheers for the link, Wilber
  8. Mr Burns
    Mr Burns
    Would someone do me a great favour and have a look on the back of the multi-media box for this Plasma and tell me what the mains input says - i.e. 110/220 v 50/60 Hz? Thanks very much.
  9. Mr Burns
    Mr Burns
    Please..............?
  10. F1ash
    F1ash
    Jun 12, 2003
    109
    Sussex
    I'll try and remember..
  11. gpedder
    gpedder
    Jul 5, 2003
    24
    4
    luton, UK
    mains input says:
    100-240 @50hz
  12. F1ash
    F1ash
    Jun 12, 2003
    109
    Sussex
    Nice one gpedder - I forgot! :rolleyes:
    I was too busy watching Gangs of New York last night.
    I can't imagine the picture quality getting any better than this on any screen of any type! Blacks were properly black too which I know is something that is moaned about generally on plasmas. BTW I had black stretch set to OFF too.
    The picture was so sharp and clear - incredible.
    Also, after watching the entire 2 and a half hours of it, plus freeze frame pauses for refreshment, I found absolutely no residual screen burn with the cinematic black bars at the top and bottom.
    I also haven't found any problem after watching lots of 4:3 sky broadcasts.
  13. Mr Burns
    Mr Burns
    Thank you!
