newbuyer17
Can anyone confirm what the differences are between these two?
According to currys the only difference is the 760 has 400Hz processing instead of the 200hz of the 670. But strangely the 760 is cheaper than the 670, at currys at least.
I've read through both the 670 and 760 dedicated threads, and am still a bit undecided and confused about this TV. The 760 seems to have problems white bleeds from the corner, and the 670 seems to have issues with movement? Is that correct, or do they both have the same potential issues?
Also a lot of discussion that some of these issues may only be present on the larger panels, so a 42" would be OK? And has it been conclusively proven that individual TVs have issues to a greater or lesser extent i.e. good ones and bad ones?
Can anyone summarise the safest option with these TVs, or is there basically no difference?
