42G20 vs 42V20
Discussion in 'What Is The Best TV For You?' started by teutonik, Nov 29, 2010.
  1. kreeeee
    kreeeee
    Aug 1, 2005
    411
    +13
    That will update one day with an advert if you are connected to freeview/the net iirc.
    I saw one, and it was simply miles off the G20.
  2. TheMeddy
    TheMeddy
    Dec 20, 2010
    5
    V20 is more advanced when broken down into the nitty gritty of the TV however the main advantages of this TV of the G series is the filter is different as opposed to infinite black you get infinite black pro which gives better black levels and natural colours (the main advantage of plasma tv) but also with the V20 this will be one of the last coloured TV's apart from black Panasonic will make this year when they move to V and G 30 so this TV's main advantage of the G is the fact that it looks visually stunning in its design. If you are buying the dongle anyway i would go for G as they are practically the same TV unless the looks of the V swing it for you :)
