4200 Amp Sound help.
Discussion in 'AV Receivers & Amplifiers' started by IanW1977, Dec 27, 2003.
  1. IanW1977
    IanW1977
    Dec 30, 2002
    4,557
    West Midlands
    +484
    Anyone know why no sound comes out of the Rear right Speaker but comes out of the Rear Left and FL.FR and Centre ??
    I use Fake 5.1 for TV but it only seems to work on the 4 speakers ?
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    have you tried chaning one of the speakers on one of the working channels to the rear right? if it still didnt work, you would know that it is either cable or amp, if it did work, you would know that the speaker was the thing at fault
    ad
  3. IanW1977
    IanW1977
    Dec 30, 2002
    4,557
    West Midlands
    +484
    Done the Test Tone and it works fine.
    Hmmm
  4. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Is this just a tv thing using prologic2
  5. pr1uk
    pr1uk
    that extra rear speaker only works when the signal is there using a fake 5.1 will not do it. if you have DVDs with say ES or EX sound you will hear it, as long as its there when you do the test it will work when the signal is there.
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I have a feeling pr1uk misread, but i might be wrong.
    As bob says, is this just with tv or does it work properly with dvd?
    ad
  7. IanW1977
    IanW1977
    Dec 30, 2002
    4,557
    West Midlands
    +484
    Well with TV in Fake 5.1 the Rear Left works as per the other front ones but the Rear right is mute.
    Tried Pirates of the Carrabean today but couldn't hear owt from either of the rears.
    Seems to only work with DTS soundtracks
  8. pr1uk
    pr1uk
    it works properly when the codex for that rear middle track is present, as it is in ES or EX DVDs
  9. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    but it isnt the rear centre we are talking about....
    ad
  10. pr1uk
    pr1uk
    your right i did not read it right ..
    if i had that problem i would think it was a connection problem like a scart no fully in.
    see thats what come of reading posts after a long day at work.
  11. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    thats probably the next step having showed the speaker not to be at fault..... it does worry me that pirates of the caribbean didnt work. You say it worked with dts..... does that mean it worked properly on all the rear channels? Does it normally work with dolby digital?
    Another thing to consider is that this is because your dvd player is set wrong, try setting it to bitstream/pcm (whatever the one it isnt on) and see what happens. This sounds a bit too random to be that, but who knows
    ad
  12. IanW1977
    IanW1977
    Dec 30, 2002
    4,557
    West Midlands
    +484
    Could be the DVD
    It was turned off for a few weeks whilst the living room got decorated.
    Will have a flick through the options when i get home
    Couldn't get Pirates of the Carribean to play in DTS though - Couldn't get it off that Audio Test thing.
