42" Starter Setup
Discussion in 'Plasma TVs' started by bazclef, Jul 31, 2005.
  1. bazclef
    bazclef
    Could someone check over this setup for me please?
    £1100 - 42" Panasonic TH42PWD7S (with 3 year guarentee) - Richer Sounds
    £140 - Pioneer VSXC301S AMP - Richer Sounds
    £120 - RGB to Plasma VGA Converter - JS
    £125 - Stand - AVSales
    Total: £1485
    RGB scart from the Amp straight into the RGB->Plasma convertor, then that into the plasma using a VGA cable.
    That Pioneer amp is cracking, 4 scart sockets for starters. Xbox/GC/PS2/CableTV/Ipod straight into the amp. Sony 5.1 speakers that I already own providing sound from the amp.
    Or should I be getting BNC component instead/as well to support prog scan?
    Thanks!
  2. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    sounds like a fine plan mate and the screen is prog scan anyway
  3. bazclef
    bazclef
    Thanks for the feedback dude. So I will get prog scan with that setup? I dont need any additional hardware?
  4. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    no..the panasonic is a prog scan screen and will deinterlace for you
  5. bazclef
    bazclef
    Top man, thanks for the reply.
  6. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    no worries...let us know how you get on!
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    Have a look at the offer at the top of the plasma section, I think you can pay a little more and have a stand, but you get a component board too.
    Yes, the forum favourite, the PWD7 is for sale at £1150, to include:- screen, BNC component board, flat wall mount, 3 yr warranty and delivered to your doorstep.
    http://www.avforums.com/forums/showthread.php?t=228959&page=1&pp=15
  8. bazclef
    bazclef
    Wow that is a cracking deal... will drop that guy an email.
    However I still dont see the advantage of having a component board rather VGA -> RGB Scart -> Amp? (however I am a complete n00b) :rolleyes:
  9. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    The colour saturation from sky going into the panny screens is too strong and you cant drop the saturation with the vga input, so instead of the JS vga transcoder go for the JS component transcoder instead.
    I would also look for an amp with component switching too, you can then have one component cable going from amp to plasma and use teh amp for switching.
    Some of the Denon amps would be better than the one you have listed and only be a few quid more.
  10. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    I have sky going via js box to vga and its superb.....this is the trouble matey .......everybody has different opinions.........:)
  11. bazclef
    bazclef
    Martin/Grahams deal is taking forever to arrange, and Richer Sounds only stock the screen in black :( I had to investigate other deals and I found 2 cracking deals:
    1.
    Panasonic TH42PWD7 + a FREE Triple Input Board (Colour: Silver Or Black)(TY-42TM6Y) Mainland UK Delivery Charge £80.00 On This Product
    This is the board it comes with, it has S-Video, component and composite... It's so big it has to be fitted over 2 slots!!
    [​IMG]
    That's £1059 delivered, and with the board!
    2.
    Panasonic TH42PWD7ES 42" Plasma + TY42TM6Y + Free DVD Recorder
    That's the Plasma, the board shown above, and a free DVD recorder (unsure on the model, will confirm it tomorrow) all for £1170 delivered!
    These sites look alright, just going to check up on their background before I select which one to order from.
  12. bazclef
    bazclef
    Panasonic TH42PA50 Plasma TV - NEW! 42" Plasma with integrated tuner and speakers, includes pedestal-stand - Mainland UK Delivery Charge £80.00 On This Product
    That's not bad either!
    Code:
    G8 (generation 8) plasma panel
    Teletext with 2000 page memory
    Picture formats: Auto, 16:9, 14:9, Just, 4:3, Zoom1, Zoom2, Zoom3
    Video
    Screen Aspect Ratio: 16:9
    Screen Size: 42"
    Number of Pixels: 852x480
    Contrast Ratio4000:1
    Audio
    Audio Output: 16W (2 x 8W)
    TV-Tuner
    Tuning System: PAL B/G/H, I, D/K. Secam B/G, D/K, L/L
    Broadcast Stereo Reception: Nicam B/G, I, German A2
    Teletext ReceptionLevel 2.5
    Terminals
    Number of scart sockets: 3
    AV1: AV+RGB in, TV out
    AV2: AV + s-video in, AV out. Q-Link
    AV3: AV + RGB + s-video in, AV out. Q-Link.
    AV4: Component in (also 720p + 1080i)
    Audio Output
  13. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    remember with the triple board you can only use two inputs at once, i.e. component and choose s-video or compostite.
