42" PWD7 for £999 at RS !!!
Discussion in 'Plasma TVs Forum' started by JohnCCFC, Jul 27, 2005.
  1. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    This has to be a bargain.
    (sorry if its been posted everywhere, did search, didn't find)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I would rather have PWD7 with 3 yr warranty wall mount and component board including delivery for £1150 from MAW RS with warranty is £1100 so from MAW with the extra £50 you get a wall mount and input board
  3. NewToyForXmas
    NewToyForXmas
    Jan 4, 2005
    75
    Where are the details of the MAW offer?
    I've got a Panny E500 Hard-drive recorder. I don't know if I can attach speakers directly to this or will need an amp - it has 5.1 outputs but I think they need to go to an amp then out to speakers. I'd also want to play PS2 and xBox on the screen. Oh and SKY+ but I guess that would go through the E500. Is the MAW set up suitable for me? Would I need anything else? £1,150 sounds very attractive.
    The PWD7 is not HD ready though, is it?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    see here http://www.avforums.com/forums/showthread.php?t=228959
    you will need a component switch box component cables for consoles and you stick Sky into E500, E500 in to switch box switch box to screen (an AV amp denon 1706/1905/1906 Pioneer VSXD915 etc is ideal as a switch box)
    there are hundreds of ways to do this i reconmend this one for VFM total cost excluding 5.1 speakers (canton CD1 £240 are ideal silver or black) is £1500 ish
