42 pv500 type of wall mount??
Discussion in 'Home Cinema Buying & Building' started by tim k, Jun 3, 2005.
  1. tim k
    tim k
    After selling my old pw6 using a universal wall mount i still have the screws fixed into my plasterboard (before you moan i know!) and it would be very convenient if the wall mount supplied fixes in the same holes. This is the same as the wall mount i used to have:
    http://www.av-sales.com/plasma/html/slimline_tilting_plasma_wall_m.html
    So anyone know if the pv500 wall mount will be the same?
  2. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    this is the 500's wall mount:
    [​IMG]
  3. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    [​IMG]
  4. tim k
    tim k
    thanks for that mate, ur a star, it seems quite different to the universal mount, its either back to the drilling or swap it for my old universal jobby!
