42" Plasma £2499 at Currys
Discussion in 'Plasma TVs Forum' started by dipatel1, Jun 5, 2003.
  1. dipatel1
    dipatel1
    does anyone know whether this is a good deal?
    Daewoo SD425 42" Plasma TV including tuner box & speakers for £2499.
    Thanks...
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,661
    Newcastle
    +103
    Have you tried a web search for reviews, just an idea.
  3. jonathan
    jonathan
    Feb 8, 2002
    155
    19
    Kent
    If their cars are anything to go by I'd steer well clear. :rotfl:
  4. cyrus-t
    cyrus-t
    Feb 28, 2004
    181
    +16
    hello.. just bought the Daewoo last week .... I was initially quite pleased ..... but .... I wanted to bypass the tuner box as I only use Sky, DVD and PS2 ..... got the DVD and PS2 wired right into the screen, but couldn't get it to recognise the Sky box for love nor money.... anyway, I wasn't too bothered about that, as keping the tuner box gives me even more inputs.....
    So far so good.....or so I thought.......
    After three days, everything has taken on a green pixelated outline and is only just watchable (whether I go via the tuner box or not) ..... and the next day, my PS2 and DVD player (which go direct in to the screen) are now unwatchable as they are almost pitch black.
    The repair man is coming tomorrow, so I hope he can fix it !
    So far, I regret buying this screen, and maybe should have found a few more £££ for something I can trust a bit more, or maybe I'm just unlucky.
    The fact that the glass plate between the legs has the logo on back to front, and that the screen buzzes loudly every time a bright image comes on, I have chosen to ignore......
    Maybe it's just dying ....
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    For 2.5k you can do so much better. That's almost Panasonic money. Certainly Hitachi money, you are so much less likely to have trouble with either of those.
  6. cyrus-t
    cyrus-t
    Feb 28, 2004
    181
    +16
    hmm.. sound like not a bad idea .. .but WOuld I get a tuner box, speakers, and stand all in the price... I did with the Daewoo (not that I would try and defend it mind you ! :0)))
  7. Elvis
    Elvis
    But you've already said you don't need the tuner.
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    And the speakers will be rubbish anyway. A stand or wall mount you will need, allow £150.
