42" High Def Plasma Screen On A £1500 Budget, possible?
Discussion in 'Plasma TVs Forum' started by about87, Aug 13, 2005.
  1. about87
    about87
    Hi Guys,
    I know that it is a big ask, but is it possible to pick up a decent 42" High Def screen on a £1500 budget? I have been looking over the net and have found the Samsung PS42S5HX avalable within this budget but other than that set I can find nothing.
    Am I better of just accepting that a decent high def screen is going to cost me £2000+ or can I actually get something in my price range. Also, any ideas of other screens to look at other than the Samsung PS42S5HX as this is the only one I have been able to find thus far.
    Cheers,
    Will
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    Hitachi 42pd5200, maybe.
    £1389.
    Have a look at the reviews.
    It does HD, but I would double check to see if it does 720 and 1080 at 50/60 hz,
    to make sure it's compatible with Skys HD
  3. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    I don't get this PD3200, the spec looks exactly the same as the PD7200 on that website, Surely there must be some features missing for it to sell at that price.
  4. bazlion
    bazlion
    Korum.
    I just noticed that after I posted it, look at my New Hitachi 42PD3200 post for more accurate info
