Thank you for your reply.. The TV is only 6 months old and I don't have an aerial only a sat dish... Picture is great but the operating system is pants... I can't get the Epg to populate either any ideas? .... Wish I had bought an LG or Samsung..!Morning. Unfortuantely not. I had this exact issue. I need to use Satellite as the house arial doesn't work.
Tedious job to do but once you've done it, its fine.
I'm unsure what year you're TV is but I would avoid any software updates. I've ran one which has remoted the option to create a favorites list.
See here:
Philips B2C
tpvcrmplus.force.com
Thanks for your reply, I too am used to freesat as I'm in France and used that for UK TV.Again, i've got the same problem.
You won't get full EPG using Satellite as this will just advertise On now and Next. I find if i leave something playing on Satellite for a while, a lot of the EPG slowly pulls through but its very hit and miss. I was used to FreeSat before this TV so it was quick a knock back when i realised i couldn't get full EPG.
My advice would be to either try and get an aerial working (even test with a indoor one) or IPTV.
