40WH08B Green cast
Discussion in 'Televisions' started by bladerunner8801, Jun 4, 2003.
  1. bladerunner8801
    bladerunner8801
    Jun 4, 2003
    397
    UK
    +30
    Toshiba 40WH08B just developed a Green cast over all the image also thin arching lines noticable, saw this once on a Sony kp46s4 i had but it disappeared when engineer came out and never saw it again had it for 4 years, looks to be here to stay on the Tosh though anyone any clues?
    Dale.
  2. nathan_silly
    nathan_silly
    Nathan "Tosh RP" tweaker is here. And I have no clue!
    Can you take a snapshot?
  3. bladerunner8801
    bladerunner8801
    Jun 4, 2003
    397
    UK
    +30
    Hi Nathan
    Heres a pic i just took, if you need any more let me know.
    Regards Dale.
  4. nathan_silly
    nathan_silly
    Adjust the Green pot that's behind the speaker grille. There are total of six. Three Focus pots & Three screen pots. Don't touch the three focus pots. Only adjust the green screen pot.
  5. bladerunner8801
    bladerunner8801
    Jun 4, 2003
    397
    UK
    +30
    Nathan your a life saver, did what you said and its all back to normal now, your a Genius thanx alot. any other tips for setting up to get the best of of these Tosh's
    Regards Dale
  6. nathan_silly
    nathan_silly
    Glad to help. :)
    Have you performed service-level convergence?
    Do a search on username "nathan_silly" and "42pw23p" and it'll bring up some posts.
    Here's two good sites...
    http://www.bus.ucf.edu/cwhite/Theater/ToshibaTips.htm
    http://www.keohi.com/keohihdtv/brandspecific/toshiba/toshiba_tips.html
    btw, I've done the following..
    Disabled SVM
    Performed twelve service level convergence's
    Refocused red, green & blue electronic focus
    Refocused red, green & blue lens focus
    Used Avia to set colour, contrast, brightness etc.
  7. bladerunner8801
    bladerunner8801
    Jun 4, 2003
    397
    UK
    +30
    Hi Nathan
    Will do that, thanx again, Tv as good as it ever was now!.
    Regards Dale.
