40w max light, what happens if I put bigger bulb in?
Discussion in 'Home Cinema Buying & Building' started by SilverPenguin7, Aug 24, 2004.
  1. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Excuse my ignorance here, but if I put a 60w or stronger bulb in a light I have that says 40w max, what will happen? The actual light is blown glass so apart from it geting hotter to the touch what else would happen? Is the actual light wired to only accept low watt bulbs, I have no idea?
  2. RustyH
    RustyH
    I have foud in the past that the higher wattage bulbs blow quicker
  3. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    hmm ok if thats the only downside I might give it a go. Thanks :)
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,840
    Somewhere in South Yorkshire
    +5,069
    You will scorch or melt the fitting/shade. A regular lightbulb uses about 98% of the energy it consumes to make heat, not light. A 60w bulb will make 50% more heat than a 40w bulb. Don't do it. If you want greater brightness, and aren't using a dimmer, use a low-energy (mini-fluorescent) bulb, of any rating you want. These are more efficient, and only just get warm.
  5. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Ah right ok, thanks for that tip buddy :)
  6. Precizion
    Precizion
    Jul 14, 2004
    It can also blow up your lamp as I recently found out :)
