400GB Drive for Sky+ ?
Discussion in 'Sky Digital TV Forum' started by booktrunk, Oct 17, 2005.
  1. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    I'm thinking about getting a 400GB drive for Sky+, it's a standard 80GB one that was installed a month ago. The drive i'm thinking of getting is a Hitachi Deskstar 7K400 400GB UDMA100 mfr#: HDS724040KLAT80
    Anyone know if this will work?
    Not to worried about noise, or if it costs a few more pennies to run in energy, I would just like to know if anyone forsees any problems with it.
    If it's noisy i'll stick it in large cupboard under the stairs so noise isn't an issue either.
    Any input would be appreciated.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    The maximum size that a Sky+ box will recognise is 250GB.
  3. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    Thanks.
    That is the info I needed to know, sorry to be a pain but do you know of any "recommended" drives that people find work well...
    I'll have a hunt through some other threads as well to find out.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    There's tons of information in this thread
    Unfortunately what works well in one make of box won't necessarily work well in another, so you do need to identify which make/model of box you have. Also, you'll find that many of the drives mentioned early in the posting are no longer available. A "rule of thumb" is to use a 5400rpm drive where possible, because they are quieter and run cooler than 7200rpm drives. Theroretically any IDE drive up to 250GB should work, but there's no guarantees. I'd recommend Technoworld as a supplier - they stock a good range, and the prices are competitive.
  5. Rash
    Rash
    5400rpm drives seem to be harder to come by now. When I upgraded a month or so ago technoworld had run out of the 160GB 5400 rpm drive, so I ended up with a 7200rpm one. So far it has worked fine.
    After i had purchased I saw someone posted a link to komplett. They stock a 5400rpm 250GB Samsung.
    http://www.komplett.co.uk/k/ki.asp?sku=308644&cks=SPC
  6. The_Munter
    The_Munter
    Feb 23, 2005
    131
    london
    Is it easy to install em? Do you just swap em out? or do you need to format it?
  7. carlosbrunos
    carlosbrunos
    Yes, very easy, its a std ide interface.
    Search google, theirs loads of examples.
