$400 budget, Looking for a gaming headset (PC / PS4 / Switch) and amp if it makes a big difference
Moco64
Hey everyone, I have a $400 budget and mostly game on my PS4 and Nintendo Switch and some on the PC, but will probably start watching movies if the headset is good enough, I listen to music every once in a while. I'm looking for a headset with surround sound, not sure if rumble is a gimmick or drives the price up it would be nice but it's not needed.
Also, I'm not sure if getting an amp makes a serious impact on the sound, so if it does, please keep that in the budget. If I have to, I'll get an amp further down the line. Finally, the headset does not need to have a mic attached, If I can buy a mic and have it work with my ps4 and the headset I buy, I'll do that.
This will be an investment for at least a few years.
I am looking for a closed back set.
Thanks a lot in advance, links are very welcome.
twoodley
If you want to use them on the PS4 they will need to be wired.
The PS4 does not connect via Bluetooth to audio devices.
Naqv
Steelseries Arctis Pro + Dac. Replace the pads with official leather alternatives and these are very very good. Mainly suitable for PS4 and PC but do work with other consoles (without the mic).
