400 budget for 17/20 inch - advice needed!
Discussion in 'LCD & LED LCD TVs Forum' started by joe.90, Oct 30, 2005.
Tags:
  1. joe.90
    joe.90
    Hi all
    am looking for either a 17 inch or 20 inch LCD TV (small room!). don't really know a lot about technical stuff but have got the impression that panasonic, philips, toshiba and sony are probably the better makes to go for. is this generally true???
    also, is there any point in getting a 17 inch widescreen or should i be going for a non widescreen when its only a small tele??
    budget is 300 - 400 but obviously i'd rather spend nearer the 300 mark
    was initially thinking about the philips PF4310 (300 quid from savacentre.com but this is widescreen.....
    any recommendations or advice would be great....
