40 NU7120 vs 40 MU6400
Discussion in 'What Is The Best TV For You?' started by MarsA7X, Jul 21, 2018.
Tags:
  1. MarsA7X
    MarsA7X
    Jul 21, 2018
    5
    Ireland
    I am looking for a new 40 to 43 inch tv and want to know which of these is better?
  2. Dodgexander
    Dodgexander
    May 29, 2007
    15,202
    +4,404
    They will be strikingly similar. On paper last years MU6400 is better as it has a wide colour gamut. Not sure how much that matters to you though as its only beneficial when you use HDR material.
  3. MarsA7X
    MarsA7X
    Jul 21, 2018
    5
    Ireland
    What about the 43 Inch NU7400? From those three, which would you recommend?
  4. Dodgexander
    Dodgexander
    May 29, 2007
    15,202
    +4,404
    If you get the same panel as this user then it also looks good:
    Samsung 43NU7400 - Looks like it's a VA panel!
    Couldn't really rate any of them over the others, just depends whether you want a wide colour gamut and also on pricing. Sometimes the new models (N series) can be more expensive because they have only just been released compared to clearance prices on the M series from 2017.
