40"+ Gaming TV for under £600
Discussion in 'What Is The Best TV For You?' started by jayd, Aug 24, 2013.
  1. jayd
    jayd
    Nov 28, 2005
    6,773
    UK
    +1,550
    Hi I'm after a bit of advice I'm after a gaming TV larger than 40" and I thought I had found my perfect match with the Sony KDL42W653ABU nut the fact that it only uses it's built in wall mount has shattered my dreams. lol. What do you recommend I get in it's place?
  2. jayd
    jayd
    Nov 28, 2005
    6,773
    UK
    +1,550
    Anyone?
  3. jayd
    jayd
    Nov 28, 2005
    6,773
    UK
    +1,550
    bump, any suggestions?
  4. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    How do you mean a built in wall mount out of interest?
    The Sonys are the best gaming TVs this year
    Try to find an end of line 42ST50 or GT50 plasma maybe?
  5. jayd
    jayd
    Nov 28, 2005
    6,773
    UK
    +1,550
    Apparently there are no holes for a VESA mount on this set and the TV stand doubles as a Wall mount which can only mount on a flat surface. My room is crippled by having 2 doors a large window and a fire place, one being on all four walls , so I need a corner wall mount which the sony cant do sadly as obviously its the best gaming set at that budget.
  6. VEGACORTEZ
    VEGACORTEZ
    Aug 6, 2006
    509
    43
    +212
    Have you looked into the samsung F5000 range the 32" model got a good rating on *, perhaps the 42 is also good although i suspect the panel won't be one of samsungs at that panel size probably AUO, not sure. Buy from amazon and return if you hate it? I presume it has vesa mounts.
  7. d3nver
    d3nver
    Feb 2, 2013
    291
    +22
    We hear good things about sonys and "Motionflow Impulse" but have yet to see it but we are ready for another tv this is what we will look at soon.
    Sony “Motionflow Impulse” reduces motion blur without interpolation | The Blur Busters
  8. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  9. redswoo
    redswoo
    Jan 2, 2008
    296
    Bristol
    +22
    46" F5000 version also within the budget if you prefer the larger size. I think its the best bet for gaming if ruling out the W6. Might even be better, I have yet to see a good comparison of the two.
  10. jayd
    jayd
    Nov 28, 2005
    6,773
    UK
    +1,550
    Thanks for all the suggestions I'll do some googling at the sets mentioned.
    Please keep suggestions coming.
  11. redswoo
    redswoo
    Jan 2, 2008
    296
    Bristol
    +22
    I have a plasma installed above fire place tilted slightly down and it works perfectly, perhaps it would suit your room also.
  12. VEGACORTEZ
    VEGACORTEZ
    Aug 6, 2006
    509
    43
    +212
    That is a good price for the 46" and i bet at that size it would hopefully have a samsung panel as well.
  13. VEGACORTEZ
    VEGACORTEZ
    Aug 6, 2006
    509
    43
    +212
