chrisevans1001
I've installed ethernet from all the points I want it in the house back to a cupboard in a spare bedroom. I kidded myself that I would be happy enough with everything housed in a rack there as I couldn't establish what problems I'd hit getting the cables into my understairs cupboard space instead. I've now decided it was wrong and would like to finish off the task and get the cables understairs.
My plan is to route them down through the airing cupboard wall. These are hollow metal frames and so dropping cables down them has been a doddle. However, I have reservations about what obstacles I am likely to hit between the airing cupboard and the under the stairs location I am trying to reach. I have attached photos below showing the route I intend to take with the half height rack located at the small end of the understairs cupboard.
Main questions:
1) Do I have tongue and groove chipboard flooring (see last picture)? If so, am I best to just cut along the join where possible and any tips for determining the best place to cut the width? I am concerned about affecting the stability of the floor. I am planning on using a circular saw to make the cut.
2) On the opposite side of the airing cupboard wall, there are 5 pipes going down into the floor. I suspect that these don't come out on the side of the wall I need to cut as all main plumbing points are located the other side but I don't know for sure and would treat with suspicion - additionally there could be heating pipes. On the stairs side, there is a consumer unit located on the back wall and I'd guess similarly that there could be electrics running in the area I intend to cut. Any tips for how I approach this situation to minimise the risk of damage? Should I use some other tool instead of a circular saw?
3) Under the flooring, is it likely that I will have free and open access to the under the stairs area or will there be some kind of fascia board? If there is a board, can I drill it without issues?
Thanks in advance!
Main questions:
Thanks in advance!
