Cakefish
I would like a 40” UHD TV to use with Xbox Series X and Switch consoles. It’s to directly replace a 40” FHD TV from circa 2015 (which only cost me £179 at the time!) that I have wall mounted. Just looking for something with better colours and resolution, I figure anything on the market today would be an improvement. Unfortunately a 43” TV would be too large to fit in place, so I’m strictly limited on size here. I searched for PC monitors too but they all cost a lot more for an equivalent size panel. Not looking to spend a fortune here, as it’s merely a secondary TV that’ll be used almost exclusively for gaming.
The two options I have found online are the Sharp BJ5K and the Panasonic JX800.
1) Sharp C40BJ5KF2FB - £279, direct lit LED backlight, HDR10, Aquos Net+ OS (Argos has the seemingly identical C40BJ4KF2FB for £300)
2) Panasonic TX40JX800B - £400, edge lit LED backlight, VA panel, HDR10+ Adaptive, Dolby Vision, ALLM, Android TV OS
To me it looks like the Panasonic is the better bet, despite costing a bit more, as it supports ALLM and is a guaranteed VA panel? I can’t find the panel type of the Sharp anywhere online and it doesn’t appear to support ALLM. Would the direct lit panel tech that the Sharp uses offer any meaningful benefit over the edge lit Panasonic?
